ocskipper Posted June 8, 2009 Share Posted June 8, 2009 Just got my rocky road adj. track bar and sway bar relocation mounts. An alignment is necessary after installation? Link to comment Share on other sites More sharing options...
Pete M Posted June 8, 2009 Share Posted June 8, 2009 What have you done so far? Give us the chronological low-down. :D Link to comment Share on other sites More sharing options...
cracker Posted June 8, 2009 Share Posted June 8, 2009 Probably not. If your 'old' track bar was the right length, just measure it out to be the same and install. If not, you may have to tweak the steering wheel to center it. Link to comment Share on other sites More sharing options...
ocskipper Posted June 8, 2009 Author Share Posted June 8, 2009 Installed V8 ZJ coils, 2 inch poly spacers, 92 xj longer sway bar links, 31" mud terrains and got it aligned. Rides good just some play in the steering and ride, not quite death wobble though. I am not sure if i even needed the track bar. Just looking at it, it seems to be fine, it is angeled slightly but everything is tight. The sway bar is hitting my coil on the passenger side though, the relocation brackets should fix that. Link to comment Share on other sites More sharing options...
Pete M Posted June 8, 2009 Share Posted June 8, 2009 The track bar locates the axle side-to-side. Keeping the stock track bar at 3" pulls the axle towards the drivers side and might be causing the contact as the components on the passenger side get closer to each other. At the least, adding it in now will probably cause your steering wheel to turn off center a bit. Link to comment Share on other sites More sharing options...
ocskipper Posted June 8, 2009 Author Share Posted June 8, 2009 ta-da! Makes total sense Pete. Thanks for the dose of common sense :nuts: , it is always appreciated. :thumbsup: Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 8, 2009 Share Posted June 8, 2009 Installed V8 ZJ coils, 2 inch poly spacers, 92 xj longer sway bar links, 31" mud terrains and got it aligned. Rides good just some play in the steering and ride, not quite death wobble though. I am not sure if i even needed the track bar. Just looking at it, it seems to be fine, it is angeled slightly but everything is tight. The sway bar is hitting my coil on the passenger side though, the relocation brackets should fix that. With a similar front lift my axle shifted about 5/8" left toward the drivers side. The below link explains how to measure this shift. Then you can adjust it out to re-center the axle w. your adjustable track bar. After that you will need to re-center the steering wheel with thr drag link. None of this should affect your alignment. http://gojeep.willyshotrod.com/HowtoTrackbar.htm Link to comment Share on other sites More sharing options...
ocskipper Posted June 8, 2009 Author Share Posted June 8, 2009 Installed V8 ZJ coils, 2 inch poly spacers, 92 xj longer sway bar links, 31" mud terrains and got it aligned. Rides good just some play in the steering and ride, not quite death wobble though. I am not sure if i even needed the track bar. Just looking at it, it seems to be fine, it is angeled slightly but everything is tight. The sway bar is hitting my coil on the passenger side though, the relocation brackets should fix that. With a similar front lift my axle shifted about 5/8" left toward the drivers side. The below link explains how to measure this shift. Then you can adjust it out to re-center the axle w. your adjustable track bar. After that you will need to re-center the steering wheel with thr drag link. None of this should affect your alignment. http://gojeep.willyshotrod.com/HowtoTrackbar.htm can't I just center the body over the axle by disconnecting the upper mount of the track bar and moving the steering wheel? Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 9, 2009 Share Posted June 9, 2009 can't I just center the body over the axle by disconnecting the upper mount of the track bar and moving the steering wheel? Not sure what you are asking here. The purpose of the adjustable track bar is to re-center the axle under the body. I don't know which adj. track bar you have, there are many different models designed for the amount of lift you have i.e. 0"-3", 3"-6", etc., but I used a 0"-3" TeraFlex unit. It has an adjustment collar like a tierod so you don't have to disco one end of it. But with your lift, you need to measure first (as in the link) to see if your axle is centered or not. If it's still centered, no worries. If it's not, you have to adjust the track bar, making it longer, until the axle is pushed back toward the passengers side and re-centered. Make sense? Link to comment Share on other sites More sharing options...
ocskipper Posted June 9, 2009 Author Share Posted June 9, 2009 can't I just center the body over the axle by disconnecting the upper mount of the track bar and moving the steering wheel? Not sure what you are asking here. The purpose of the adjustable track bar is to re-center the axle under the body. I don't know which adj. track bar you have, there are many different models designed for the amount of lift you have i.e. 0"-3", 3"-6", etc., but I used a 0"-3" TeraFlex unit. It has an adjustment collar like a tierod so you don't have to disco one end of it. But with your lift, you need to measure first (as in the link) to see if your axle is centered or not. If it's still centered, no worries. If it's not, you have to adjust the track bar, making it longer, until the axle is pushed back toward the passengers side and re-centered. Make sense? It does now, thanks for clearing the fog guys. :thumbsup: Link to comment Share on other sites More sharing options...
