mjtjnj Posted June 8, 2009 Share Posted June 8, 2009 The a/c compressor is making some awful noise. When I replaced the engine last summer, I replaced the condensor just to be complete, but I really don't care if it works or not at this time, not interested in the expense. Well, with the compressor making all this noise, I'm worried about seizing and snapping the serp. belt. Got the bearing for $24 or so from rockauto. What is there to this? Is it straightforward? The FSM makes it look like you need a couple of pullers, one is like a steering wheel puller, but the other -- ??? Anyone done this? Thanks Tom :waving: Link to comment Share on other sites More sharing options...
Pete M Posted June 16, 2009 Share Posted June 16, 2009 bump for ya. After reading the question in the Pub (not specifically about our trucks) I was wondering if the pulley pullers were really necessary. Link to comment Share on other sites More sharing options...
1987Comanche Posted June 17, 2009 Share Posted June 17, 2009 I tried this on my '96 Beretta and it was a royal PITA. The problem is not replacing the hub and bearing assy (yes, you will need the A/C clutch holder tool) rather it's trying to get the air gap correct when you reassemble it. I couldn't get the clutch to engage because of the air gap. Not sure if the alignment would be off far enough to affect the serpentine belt...I didn't let it run long enough to find out. Link to comment Share on other sites More sharing options...
