power steering revisited....is it dying...?
so my power steering will sometimes cut out.... weird...but at low speeds or idle it seems to work correctly then as I accelerate and turn it will work then cut out...then work again... so steering is getting to be a little bit difficult. Any ideas, is this a pump starting to fail, a line clogged, or what????... thanks
depending on what gear and pump you have, there is a filter in it as well. You have to remove the line and fish it out and then just use some cleaner on it. It has been a long time but seems it is in the box side of the pressure line.
