If I use a Dakota rear brake line, will it have the "junction block" built in as part of the brake line? Or do I need a separate junction block.
That is the way it is with the stock D35 setup.
My plan is to use a r/side line on the left side, hardline both sides to a "junction block" IE: Dakota?
