Truck won't run. *VIDEO* Need idea's
AMC place is www.amc4x4.com (Jeep parts and stuff.. smart people)
Got the pump/sending unit out.. found hose disconnected.. replaced hose (was a chunk of black rubber/string)
Ended up dropping the tank to get it all back right.. it ran last night ok.. but gauge is reading PAST FULL and not moving
Today I drove it a bit.. and it's spitting and sputtering.. almost didn't make it home.
going to go borrow buddy's Toyota.. and put this on hold till sat..
Plan is to Drop the tank.. again.. and pull it all down and replace the pump..
Did look inside the tank..and it's in almost perfect shape.. no rust no floaters.. nothing.. just clear clean gas.
Fuel pump
fixed the "Hose"
ran it wed night.. it was ok..
thur morning no go.
Sat fri while I did other things
Sat buddy tried to drive it to my parents. Made it 2 miles and it died.
Dropped the tank. New Pump.. runs like a champ now.
I wonder if I can get a tank to fit UNDER my truck box.. and run the filler up into the box.
  CWLONGSHOT said:
Well, before seeing your clip, my first thought was also the CPS. A bad fuel pump can do strange things like this.
  Qui Gon-Jinn said:
Hoping it's not the pump. that is not an easy fix.
Its not a very hard job!! I have done it three times on my MJ alone!! (I keep getting bad units!)
CW
Glad it all worked out!! I am on the third pump in my MJ.....
CW
