sinnaevd Posted August 10, 2006 Share Posted August 10, 2006 can you bolt an 87 chev truck 2x4, to any 4x4 frame within the same year range wihtout n e mods? I've been looking all over the net and dunno where i can find this info. anyone know any sites that may be able to help??? Link to comment Share on other sites More sharing options...
JOMJ87 Posted August 10, 2006 Share Posted August 10, 2006 Are you talking the body or all componets? IE( motor, trans,.........) Cole Link to comment Share on other sites More sharing options...
sinnaevd Posted August 10, 2006 Author Share Posted August 10, 2006 i'm talking body. i can make the other components fit, but the 2wd frames and the 4wd frames are supoosedly way to different to even bother trying to swap everything over. so i want to put my 2wd onto the 4wd frame. Link to comment Share on other sites More sharing options...
GirsMJ86 Posted August 10, 2006 Share Posted August 10, 2006 bodies did not change all that much between 73 and 87. so you can bolt right up with very little mods. and try www.myoldtruck.com for help on those trucks. alex Link to comment Share on other sites More sharing options...
Hot Rod Jeep Posted August 10, 2006 Share Posted August 10, 2006 The 2wd transmission hump is smaller than the 4wd hump. I think it's only a couple inches difference, but I don't know what kind of clearence issues that'll bring up. You might be able to just cut the 4wd hump out and bolt it in the 2wd's place or use a body lift. Something to check into before you go setting the 2wd cab on the frame then then find out. 8) Link to comment Share on other sites More sharing options...
87manche Posted August 11, 2006 Share Posted August 11, 2006 Hot Rod Jeep said: The 2wd transmission hump is smaller than the 4wd hump. I think it's only a couple inches difference, but I don't know what kind of clearence issues that'll bring up. You might be able to just cut the 4wd hump out and bolt it in the 2wd's place or use a body lift. Something to check into before you go setting the 2wd cab on the frame then then find out. 8) everything can be clearanced with a sawzall :) Link to comment Share on other sites More sharing options...
feerocknok Posted August 11, 2006 Share Posted August 11, 2006 I hate body lifts, but if that's the case, it's super easy to do! http://67-72chevytrucks.com/vboard/ The forum is apparently for 67-72 trucks, but they're super knowledgable on the newer ones too! Link to comment Share on other sites More sharing options...
Hot Rod Jeep Posted August 11, 2006 Share Posted August 11, 2006 I hate body lifts too, I just didn't know how good his fab skills were. 8) Link to comment Share on other sites More sharing options...
mjeff87 Posted August 11, 2006 Share Posted August 11, 2006 87manche said: everything can be clearanced with a sawzall :) and/or a cutoff wheel :evil: Link to comment Share on other sites More sharing options...
sinnaevd Posted August 11, 2006 Author Share Posted August 11, 2006 i mi ght raise the body (although i don't like it either fella's) simply because if I want to take it back to origional I can withough doing the body work. but then again, i would have to cut a whole to put the tcase shifter in n e way so we'll see. i'm not afraid of the welding, its just sumthing i don't like doign on sheet metal thanks for the sites. i will check them out this weekend. Thanks for the help everyone Link to comment Share on other sites More sharing options...
pingpong Posted August 11, 2006 Share Posted August 11, 2006 mjeff87 said: 87manche said: everything can be clearanced with a sawzall :) and/or a cutoff wheel :evil: you forgot to add a torch... and a welding machine is needed to put it back together :smart: Link to comment Share on other sites More sharing options...
