Worlds Fastest Comanche Posted April 26, 2009 Share Posted April 26, 2009 What is the difference between the 2wd 86-87 rotors and the 88 on. The parts books show an "integrted hub" What does that mean? Anybody got pictures? I was wondering of one style might be better for high speed. Link to comment Share on other sites More sharing options...
mvusse Posted April 26, 2009 Share Posted April 26, 2009 I know 88 and older hubs are different from the 89 and newer hubs. And ABS axles do not work with the older ones as the ABS ring interferes with the hub. Dunno about rotors, though. Link to comment Share on other sites More sharing options...
dasbulliwagen Posted April 27, 2009 Share Posted April 27, 2009 2wd rotors have the seperate bearings and races that go inside the rotor and then are attached to the spindle all together. The 4wd rotors just slip on over the hub unit which is bolted to the knuckle, and the wheel hold the rotor in place when it is bolted on. I am assuming the 88 on 2wd rotors are the same as the 4wd style just explained. As to which is better at high speed? Who knows? Good luck! Link to comment Share on other sites More sharing options...
HOrnbrod Posted April 27, 2009 Share Posted April 27, 2009 2WD 86-92 MJ/XJ 4WD 90-92 MJ, 90-99 XJ The 2WD front brake assembly is lighter, so I imagine it would be better for your purposes. Link to comment Share on other sites More sharing options...
Eagle Posted April 27, 2009 Share Posted April 27, 2009 The upper photo above is the same as any front hub/rotor for a rear wheel drive car. The XJs and MJs from the years that used that had a conventional (2WD type) front spindle, with standard wheel bearings thay you could (and should) repack every 10,000 miles or so. In the other years they used the same hub/bearing unit as the 4WD models, with just a dummy stub axle insert to hold everything together. Link to comment Share on other sites More sharing options...
Worlds Fastest Comanche Posted April 27, 2009 Author Share Posted April 27, 2009 So what year did they switch to a unit bearing like the 4wd? Link to comment Share on other sites More sharing options...
