pilotblake Posted April 15, 2009 Author Share Posted April 15, 2009 I am fairly sure my temp sensor is reading right. I havent used a heat gun or anything, but I put a 160 stat in for the winter and when the thing would first warm up the temp would rise then level off at 160-180 but then on the highway would not drop any lower than 160. With the thermostat out it would never get to 160 on the road. How would I run 2 radiators or extra cooling tank. I do have another all aluminum closed loop style radiator in the garage that is new. How do I join the two? And at what point do do I upgrade the water pump? Link to comment Share on other sites More sharing options...
TNT Posted April 15, 2009 Share Posted April 15, 2009 Here is a great link for radiators, fans and sensors. Explore it some,They should have what you need http://www.northernfactory.com/storefrontB2CWEB/ Here is another link check the tripple pass versions out. http://www.usradiator.com/USR-Aluminum.pdf here's is a good link for information http://www.dewitts.com/pages/whyaluminum.asp Link to comment Share on other sites More sharing options...
FxRacing282 Posted April 16, 2009 Share Posted April 16, 2009 well to run dual you would want to make sure you have enough clearance in front of the motor. you would have to drill and solder it together. but it would greatly increase cooling capabilities. Link to comment Share on other sites More sharing options...
pilotblake Posted April 16, 2009 Author Share Posted April 16, 2009 Well as much as I hate to do so I think I am going to just throw money at Manche and hope for the best. I like to keep things to a minimal as far as complex systems, so I am going to try a different radiator. Here is what its down too: Summitt sells one for - $499 + s/h. It says it is for a SBC conversion. I would have to take there word. won't ship till first of may Griffin Radiator will make one for $565 + $40 s/h. The guy says it will do the job easily. 2 week build time U.S Radiator needs me to send in my old one as a template, and prices START at $500 + s/h Northen Radiator does not make one, they said to see if they had something else that would fit The winner in my book both for cost and accountability is Superior Radiator. They will make one for $320 + $40 s/h. The guy said that they have a guy in the office or was good friends with a guy that has an XJ with a supercharged 360 and that he hasn't had any problems overheating. He sounded sincere, you can ususually pick up on if people are full of sh!% anybody had any positive/negative encounters with Superior Radiator or any of the above mentioned? Link to comment Share on other sites More sharing options...
jbhill Posted April 16, 2009 Share Posted April 16, 2009 link to said superiror rad.? Link to comment Share on other sites More sharing options...
pilotblake Posted April 16, 2009 Author Share Posted April 16, 2009 They said there website is down for remodeling or improving etc. This is the link that I found to get the phone number. http://www.superiorradiator.com/ Link to comment Share on other sites More sharing options...
jbhill Posted April 17, 2009 Share Posted April 17, 2009 interesting. I'm thinkin of using 2 3000 cfm fans to keep it cool. Link to comment Share on other sites More sharing options...
pilotblake Posted April 17, 2009 Author Share Posted April 17, 2009 What is your source for these fans? SPAL fans are way too high priced? Link to comment Share on other sites More sharing options...
jbhill Posted April 17, 2009 Share Posted April 17, 2009 autoloc/zirgo/hauffman group. there chrome to. Link to comment Share on other sites More sharing options...
dasbulliwagen Posted April 17, 2009 Share Posted April 17, 2009 Another thing Ive always heard good things of is Water wetter, an additive to put in your cooling system that helps the water transfer heat faster....something to do with breaking down the waters surface tension to allow more contact between the water molecules and the inner surface of the radiator. They sell that brand or something like it at most parts stores or performance shops. Link to comment Share on other sites More sharing options...
troy6187 Posted April 17, 2009 Share Posted April 17, 2009 I went through something like this when i had my xj with a sbc. I used a three core brass and copper radiator From a bronco ll with a v6. On the road or idling it never went over 180-200 depending on outside air temp. Offroad however it would overheat in 15 minutes. Make sure all the airflow from the grill is going through the rad. Block off unneccesary holes in the rad support. You will also definately need to find a way to let hot air out of the Engine bay. Space the back of the hood up, install vents, or a scoop of some kind. And as far as the electric fan debate? You can't beAt the two speed fans from a ford taurus! Link to comment Share on other sites More sharing options...
pilotblake Posted April 18, 2009 Author Share Posted April 18, 2009 What years for the taurus fans? also what is needed to run them two speed? Link to comment Share on other sites More sharing options...
jbhill Posted April 18, 2009 Share Posted April 18, 2009 i doubt the taurus fans would fit, there huge! Link to comment Share on other sites More sharing options...
troy6187 Posted April 18, 2009 Share Posted April 18, 2009 I would not have suggested the taurus fan if it would not fit. Many people have been using these in xj's for years. Granted, its not a drop in relplacement, but they can be used. Early to mid 90's taurus' with the v6 came with the 2-speed fans. Search on naxja or visit gojeeps site for write-ups. The 2-speeds get wired like any other fan. There sre just two circuits to wire instead of just one. And the high speed needs an 80 amp relay. There is not an aftermarket fan that pulls near the same cfm as these fans. If this is something you look for on ebay make sure it is a stock replacement fan. Some of the cheap replacements are not two speed. Link to comment Share on other sites More sharing options...
jbhill Posted April 20, 2009 Share Posted April 20, 2009 pics of the taurus fans in stalled? Link to comment Share on other sites More sharing options...
troy6187 Posted April 20, 2009 Share Posted April 20, 2009 Like i said above... Search on naxja or gojeeps site Link to comment Share on other sites More sharing options...
jbhill Posted April 20, 2009 Share Posted April 20, 2009 http://gojeep.willyshotrod.com/HowtoTaurusFanInstall1.htm well ill be an sob.... Link to comment Share on other sites More sharing options...
TNT Posted April 22, 2009 Share Posted April 22, 2009 Check out the dimensions of A 94-98 ZJ radiator. It should fit between the steering gear and the frame rail. It is also meant to be able to cool a 5.9 Magnum engine. It also is about the correct size for a Taurus fan. The V-8 radiator has a passenger side lower hose and a drivers side upper hose. It should solve your cooling problems and be budget friendly. :cheers: Link to comment Share on other sites More sharing options...
pilotblake Posted April 22, 2009 Author Share Posted April 22, 2009 Thanks for all the info, it has been very helpful :thumbsup: . Hopefully more is added if seen fit and this can become a tool for others wanting info on a V8 radiator swap since all the key search words are in the title. I went ahead and ordered the superior custom all aluminum radiator, and the guy assured me that if this doesnt do the trick nothing will. I am hoping that this doesnt just mean nothing will work :fool: . I am still going to look into the ZJ Rad. I just couldnt find much that was designed for a V8 but was narrow enough for a cherokee. I will post up pics of the progress. Also what are people paying for used taurus fans? Everyplace I have checked wants around $50 for a used fan? :fs1: Link to comment Share on other sites More sharing options...
jbhill Posted April 22, 2009 Share Posted April 22, 2009 50 sounds cheap, but is there a pullapart near you? ZJ is grand cherokee correct? Link to comment Share on other sites More sharing options...
jbhill Posted April 22, 2009 Share Posted April 22, 2009 hmm the zj rad might fit, its 260 bux tho! found this info on autozones website. Part Number: CU1394 Weight: 14.75 lbs Warranty: LLT Core Material: Aluminum Tank Material: Plastic Height: 19 5/8 inch Width: 22 1/4 inch Depth: 1 1/4 inch Number of Rows: 1 Inlet Header: 2 3/8 inch x 20 1/2 inch Outlet Header: 2 3/8 inch x 20 1/2 inch Inlet: 1 1/2 inch Outlet: 1 3/4 inch Engine Oil Cooler: N/A Transmission Oil Cooler: 12 inch (Concentric) but its only a single core for hte 5.2(318) it prob wouldnt work for me as I'm RHD and don't have factory jeep front rails... Link to comment Share on other sites More sharing options...
jbhill Posted April 22, 2009 Share Posted April 22, 2009 ok i just went and took some measure ments, it looks like the zj rad will work with a lil bit of trimming. the bottom of the rad should sit about on the bottom of the front xmember once u cut out the top of the stock crossmember. its narrow enough you can move it to one side to offset for the steering gear. here's the dimensions i got off of my 3 core rad. H-11 3/8 W 36 1/4 D- 3 1/4 it would make it more vunerable for offroad rigs tho... time to hit the j yard.... Link to comment Share on other sites More sharing options...
pilotblake Posted April 22, 2009 Author Share Posted April 22, 2009 Try this place. I buy alot of stuff from here and the prices are always good. http://www.rockauto.com/catalog/raframecatalog.php Link to comment Share on other sites More sharing options...
TNT Posted April 22, 2009 Share Posted April 22, 2009 ZJ - 2 core all aluminum radiator with 1" wide cores. :brows: http://www.rondavisradiators.com/radgallery.htm :cheers: Link to comment Share on other sites More sharing options...
pilotblake Posted April 22, 2009 Author Share Posted April 22, 2009 Ron Davis radiators wanted $649 + shipping. I'm getting essentially the same thing shipped for $350 all aluminum 2 core 1" tubes custom built for superior radiator Link to comment Share on other sites More sharing options...
