I have a 1990 2.5 . The power steering hose was leaking so i tride to tighten. I broke it know big deal until i took some kind of sensor of the power steering. It broke so do i need to replace this sensor or can i bypass sorry i do not have pictures
just ignore the sensor...it has no real function.
The PS pressure sensor's function is to increase the RPMs of the engine slightly when your in the stops of the steering gear. Found only on the anemic 2.5L. :D If your engine doesn't stall out when doing hard turns, forget about it.
I am in process of replaceing the Exhaust manifold along with the high pressure PS hose and I saw the connector just hanging there and nothing to connect to.I have no stalling issues but now I know what the connector goes to.
Finally got the hose replaced today. The old one didnt have a place for a switch but the replacement has a 1/8" pipe plug hole in it for a switch, it also came with a pipe plug to cap it off if not needed. :D
