djag12 Posted April 6, 2009 Posted April 6, 2009 I resealed my rear window and seemed to have fixed that leak since it is not dripping anymore. However, it rained again today and it looks to be coming in from he seem on the rear of the cab. Has anyone experienced this or does anyone know of any other possible rear cab leaks.
garmj Posted April 7, 2009 Posted April 7, 2009 On the "B" pillar just behind the doors on each side are plastic trim pieces,under those are plastic flapper valves that let air out of the cab when you close the doors and keep water from entering.Just pop the exterior trim off and inspect those vents to make sure they are there and intact.When I got my MJ one was missing and water leaded into the truck creatind a rust problem on the floors.
djag12 Posted April 7, 2009 Author Posted April 7, 2009 Do you mean the black vents behind the doors? If not I not sure what you mean.
Pete M Posted April 7, 2009 Posted April 7, 2009 Yup, I do believe that's what he's referring to. I've had leaky seals on the back window too. Baby powder can help track down leaks. :thumbsup:
