possum Posted April 2, 2009 Posted April 2, 2009 What ohm do the sending units operate at on our trucks. I need to buy a sending unit for my fuel cell. My truck is a 1986 LWB with the 2.8v6. Thank you. :cheers:
mfpdm Posted April 3, 2009 Posted April 3, 2009 From what I can find on the NET, most say 0-90 ohms. Here's a link that tells you how to find out from your current sending unit (if you have it and it's not broke) http://www.stewartwarner.com/tech/faqSd.html :cheers: EDIT: Just went out and played Mr. Wizard with my volt meter using the instructions from that link. Had two different years and one came out 5-95 ohms and the other came out 10-110 ohms. I'd give them a fudge factor of + or - 5. I've got an 86 one somewhere, so when I find it, I'll check it out as well. I figure since they used the same gauge up to the point they went HO, they should all read the same.
mfpdm Posted April 3, 2009 Posted April 3, 2009 Found the 86 unit and it was 6-98 ohms so I think that would be enough to convince me that the 0-90 would be right. :cheers:
Geonovast Posted April 3, 2009 Posted April 3, 2009 From what I can find on the NET, most say 0-90 ohms. Here's a link that tells you how to find out from your current sending unit (if you have it and it's not broke I thought the 2.8 had a mechanical pull-style pump. :dunno:
ren Posted April 3, 2009 Posted April 3, 2009 Sending units use electricty to measure the fuel level in the tank, wether or not the engine is injected or carbed.
Geonovast Posted April 3, 2009 Posted April 3, 2009 Sending units use electricty to measure the fuel level in the tank, wether or not the engine is injected or carbed. True... was thinking he want pump for some reason.. :doh:
