Oizarod115 Posted August 1, 2006 Share Posted August 1, 2006 this may sound stupid, however! i have to ask. whats the easiest/best way to fill a tranny without buying some oil pump, and does anyone know what size the fill plug should be? also, would the same gear oil for a diff be acceptable in my goat? or does it have to be GL-3 75-90 (ive already got some GL-5 80-90) i know GL5 eats the synchros in AX15s but what about BA10s? Link to comment Share on other sites More sharing options...
mjeff87 Posted August 1, 2006 Share Posted August 1, 2006 Not sure about a BA10/5, but on the AX- series trannies, I pop the shifter out of the top housing and dump it in from inside the cab. Just put a drain pan under the fill plug and dump 'till it starts coming out. I don't think the shifter is retained the same way on yours tho....you may have to unbolt it. Either way, it's a whole lot easier than trying to fill it via the fill hole :D Jeff Link to comment Share on other sites More sharing options...
Pete M Posted August 1, 2006 Share Posted August 1, 2006 The BA-10 fill plug is on the passenger side of the trans (I think). It takes a square metric tool and most of us take an old 3/8" ratchet extension and ground it down slightly to fit the hole. Oh, and the Peugeot will take regular ol' GL-5. Link to comment Share on other sites More sharing options...
Oizarod115 Posted August 1, 2006 Author Share Posted August 1, 2006 thats for all the advice/ideas. i knew i wouldnt feel dumb after asking. (i was gonna try a long hose connected to the bottle of oil held upside down beside the truck... wouldve taken years i bet.) Link to comment Share on other sites More sharing options...
