E brake cables
Now that I finished the SOA on my truck it is time to fix some of the unforeseen issues. First one I am going to tackle is the fact that the e brake cables are too short to reach the bed side mount where the two cables meet the actuator and the front cable connects. I', sure that I am not the first person to have a problem with this. What did you other guys do about it. The other problem I have is that my extended SS rear line is still too short! anyone know where I can get an even longer extension rear brake line that will bolt up?
Thanks,
-James
I'm not sure how the clearance is to the rear driveshaft, but maybe you could make a dropdown or spacer for the rear ebrake splitter, that should give you some extra cable room. I'm not sure what evryone else has done, but Id be curious to find out as an SOA will be in my future. Good luck!
