Shock mounts
Ok, so I found a rear shock app on the Edelbrock sale that I feel will be a good match. The Toyota T100 rears are pretty darn close on suggested specs for collapsed and extended on 2-3" lift. Plus, since Edelbrock says each shock model is tuned specifically for the model application, I'd rather have a shock that was valved for a pickup than an SUV. Anyway, my question is, before I order do I need to worry about anything as far as the eyelets go? Should these bolt right up, especially with the bottom mounts being a "side pin" style?
