comancheman Posted July 25, 2006 Share Posted July 25, 2006 i've got a short bed comanche and there is a lot of rust over the wheel well and on other places i was wondering if it would be possible to weld in rear quarters from a 2 door xj or at least most of the quarter panel any ideas? Link to comment Share on other sites More sharing options...
87manche Posted July 25, 2006 Share Posted July 25, 2006 it's been discussed. They will fit, but it will be far from perfect. They might be god to use for the crease, and then you could make your own sheetmetal from there. My MJ has been repaired there, it was seamed just below the crease with flat sheetmetal, then some light body work ws done to blend it in. Link to comment Share on other sites More sharing options...
Eagle Posted July 25, 2006 Share Posted July 25, 2006 It will always look like a cobbled up patch job, because that's what it will be. The XJ wheel arch opening is smaller in both height and length, and IIRC the height from the bottom of the panel to the first body crease is also different. A friend of mine used XJ quarters to get his beater MJ through safety inspection. It didn't have open rust holes, but it sure wasn't pretty. Link to comment Share on other sites More sharing options...
DirtyComanche Posted July 25, 2006 Share Posted July 25, 2006 Ditch the bed and flatdeck it. Image Not Found Or be like Pat and just cut the frame off too. Link to comment Share on other sites More sharing options...
pingpong Posted July 25, 2006 Share Posted July 25, 2006 The bad thing was.. my bed was rust free :eek: and so was the frame :D They just had a few dents in them :driving: As much as I love my truggy.. it isn't for everyone.. you need to have a tow rig and a trailer once you get to the level of destruction on my rig :brows: Pong just inst streetable.. thats why I am building Casper :nanner: Link to comment Share on other sites More sharing options...
sinnaevd Posted July 25, 2006 Share Posted July 25, 2006 You can get the patch panels depending on how extensive the rust is. When I contact sherman to ask if they were over going to stamp fill blown rear quarters for the bed, they said they were workign on getting the stamping dies. but for now, check the panels at shermanparts.com . they might cover the size of the wholes you have, and I know of a couple guys who have used them and had good results. Link to comment Share on other sites More sharing options...
comancheman Posted July 26, 2006 Author Share Posted July 26, 2006 will definetly check out sherman parts and as for the flat deck, the beds already off the frame (or what remains of the frame) and a flat bed wouldnt be a bad idea but i just really like the way the comanche looks with the short bed. If it makes you happy though a sledge hammer was involved in bed removal Link to comment Share on other sites More sharing options...
pingpong Posted July 26, 2006 Share Posted July 26, 2006 I only get filled full of GLEE when torches and plasma cutters are used for removal of body parts :teehee: Link to comment Share on other sites More sharing options...
sinnaevd Posted July 26, 2006 Share Posted July 26, 2006 but it makes for such a messy cleanup. i prefer the nibbler Link to comment Share on other sites More sharing options...
pingpong Posted July 26, 2006 Share Posted July 26, 2006 plasma cutter = almost no clean up if used right :brows: As for the torch.. yeah you have to chip and grind some slag.. but it just so much faster then most other methods Link to comment Share on other sites More sharing options...
sinnaevd Posted July 26, 2006 Share Posted July 26, 2006 I suppose, I hate the warp you can get from using the heat like that, more then likely due to my inexperience/lack of techinique Link to comment Share on other sites More sharing options...
pingpong Posted July 26, 2006 Share Posted July 26, 2006 If used properly.. you will get no more distortion out of a plasma then you wil out of using a cut off wheel Link to comment Share on other sites More sharing options...
