lower jeep Posted February 22, 2009 Share Posted February 22, 2009 so i started my truck up yesterday to start working on it again started just fine backed it up, turned it off to switch gears (need to bleed to clutch) then put it in 1st to move it into the garage and nothing on power to anything no power to my aftermarket fuse panel no lights no power to my air compressor for the air ride , i checked the battery just fine, replaced with a differnt battery, and nothin made sure all the wires were hooked up right no fuses were blown the battery wires looked fine, then checked to see if i had a good ground with a test light (from the + battery post to the body) and had power but couldnt find a dvom to see how much power i actually had but both batterys were just takin off the trickle chargers any body know what is wrong or had the same problems???????? thanks Link to comment Share on other sites More sharing options...
Red 1989 MJ Posted February 23, 2009 Share Posted February 23, 2009 Maybe, it's your ignition switch. Check at the bottom of steering colum. Link to comment Share on other sites More sharing options...
BLHTAZ Posted February 23, 2009 Share Posted February 23, 2009 I am not good with electrical issues so I won't even try to work on this one, but it may help someone help you if you posted some info about exactly what you are working on...year, engine etc, etc... :idea: Link to comment Share on other sites More sharing options...
MonkUSMC Posted February 23, 2009 Share Posted February 23, 2009 Alternator? My moms beemer had a similiar problem and that's what was wrong with it. I'm not an electrical person so don't really go by me lol. Link to comment Share on other sites More sharing options...
