Rockyrider367 Posted February 20, 2009 Share Posted February 20, 2009 Hi I am looking to swap my auto out on my 86 2.5 4wd to a 5spd Ax5 from a '95 wrangler. I already have all the clutch parts including the external slave master and everything all new. I didnt know if anyone had done this sort of swap before and what i should watch out for? i got a diffrent shifter for it from a cherokee with a Ax5. I was just wondering what I should watch for when doing this and if the cross member will fit for the swap? Thanks Link to comment Share on other sites More sharing options...
Eagle Posted February 20, 2009 Share Posted February 20, 2009 The cross member will be the same, but the tranny mount won't. And you may need to move the cross member to the other mounting location, which will mean moving the studs. The other "gotcha" is that the '95 flywheel won't work in your vehicle. The '86 throttle body injection is a Renix system that uses the same CPS as the early 4.0L engines. From '91 on, the Chrysler system used a different system with a different type of CPS that requires different trigger teeth/bumps on the flywheel. Link to comment Share on other sites More sharing options...
Rockyrider367 Posted February 20, 2009 Author Share Posted February 20, 2009 The motor was origionaly on this tranny anyway. I blew the motor and found this combo real cheap. So all that should be fine and i do have the flywheel from the setup and its being surfaced now. Link to comment Share on other sites More sharing options...
Pete M Posted February 20, 2009 Share Posted February 20, 2009 Are you using the old injection system? The motor block doesn't matter, the flywheel needs to match the injection system. :thumbsup: Link to comment Share on other sites More sharing options...
Rockyrider367 Posted February 20, 2009 Author Share Posted February 20, 2009 yeah i do plan on ussing the old injection system. i do have the multi port that came with the new motor but origionaly i was planiing on ussing the old injection system. Would I have to change this to get it to run right? Link to comment Share on other sites More sharing options...
Eagle Posted February 20, 2009 Share Posted February 20, 2009 yeah i do plan on ussing the old injection system. i do have the multi port that came with the new motor but origionaly i was planiing on ussing the old injection system. Would I have to change this to get it to run right? To run right? You have to change the flywheel to get it to run at all. The two systems are not compatible. To use the early (Renix) injection/ignition system, you must use a flywheel from an '86 - '90 engine. And you must use the CPS for a Renix engine, not the CPS that was in the '95. Link to comment Share on other sites More sharing options...
Rockyrider367 Posted February 20, 2009 Author Share Posted February 20, 2009 Could I use a fly wheel front a 86-90 4.0? or is that diffrent to. Link to comment Share on other sites More sharing options...
Eagle Posted February 20, 2009 Share Posted February 20, 2009 Could I use a fly wheel front a 86-90 4.0? or is that diffrent to. Nope. First, it's the wrong size and probably wouldn't even fit the 2.5L bell housing. Second, it wouldn't be balanced for a 4-cylinder engine. Third, it's set up to fire three times in one revolution. The 4-cylinder engine only fires two times per revolution. Yiou have to use a flywheel from an '86 thru '90 Jeep 2.5L. (And remember, Jeep used the 2.5L in 1984 and 1985 in the Cherokee and Wrangler, but those engines were carbureted and do not have the trigger ring with the teeth or bumps needed to make the CPS function. The flywheel MUST be from an '86 thru '90. Link to comment Share on other sites More sharing options...
Rockyrider367 Posted February 21, 2009 Author Share Posted February 21, 2009 Haha wow i can't even belive I asked that. Sorry didnt think that through. Well proablem should be solved i just went and order a new one that will be in monday for an 86 2.5 manual comanche. it was only 60 bucks so wasnt a big deal in the end. Link to comment Share on other sites More sharing options...
