All this talk about the LH tail light ground being so important, I decided to check.
Although it didn't appear bad, I wire-brushed everything to bright shiny metal,
screwed it down tight, and covered with grease. I noticed that the upper outboard
taillight attach screw hole in the sheet metal was all warbled out (explains the missing screw),
and I repaired it by filing it out square with a jeweler's file until I could press-fit one
of those square plastic inserts used for the grille attach screws. Works like a champ.
Very good idea! :thumbsup:
