neohic Posted February 27 Author Share Posted February 27 It’s been gone over, but you know you did good when you keep turning around when you park your truck. Link to comment Share on other sites More sharing options...
neohic Posted March 9 Author Share Posted March 9 I’ve been thinking about towing the CJ because I apparently like making questionable decisions. The cooler is from the ZJ I pulled the axles from along with the bracket. This was a no-drill install which was nice. I tapped into the cool line coming out of the radiator. Quick touch up with a little black and it disappears behind the grill. I’ve never had any transmission cooling issues, but I’ve also never really pulled anything with this truck over a long distance. Figured it couldn’t hurt and I had everything on hand. Link to comment Share on other sites More sharing options...
neohic Posted 21 hours ago Author Share Posted 21 hours ago After getting back from Moab I noticed a puddle of brake fluid under the left rear wheel. I swapped out both of the wheel cylinders today along with finally compounded and quick waxed the truck for the first time in a very long while. Mmm… always worth that extra look back. Link to comment Share on other sites More sharing options...
