proportioning valve
BPB
I am installing a dual diaphram brake booster. I am also doing away with the rear proportioning valve. Should i use the zj 60/40, or the xj which I believe is 70/30. Keep in mind that I have those huge dana 60 brakes out back.
I think that I am going to go with the xj valve. I was told that disc brakes take less power then drums. Worst case I have to go and buy an adjustable proportioning valve, maybe I could use one from an f250 seeings how that's the truck my axles are off of.
If my xj valve doesn't work out right then I will probably use that method. Did you mount it under your hood? I also saw that they have one that would completely replace the unit below the master cylinder for about a hundred bucks. We'll have to wait and see. won't have the rear axle back till the end of the week.
