87manche Posted October 17, 2005 Share Posted October 17, 2005 so, now that I've determined what tranny I've got, and it is the AX-15 I need to get around to fixing the syncros before the gears are totally hosed. I've got weak syncros going from 1st to 2nd and 2nd to third. I've been matching RPMs, but sometimes it gets ugly. I've also got that nagging bearing noise and I think that's the input shaft bearing. I've gotten the Jeep component manual for the AX-15. I was considering a rebuild kit. They're cheap http://cgi.ebay.com/ebaymotors/Jeep-85- ... dZViewItem How much of a task is this? I'm mechanically inclined, and pulling the tranny and putting it back in I'm pretty sure I could handle in a few hours. I've never been inside of a tranny though, and I don't have any special tools for it. Has anyone done this? Tell me theres a transmission guy in here. If I bought the parts how much do you think a tranny shop would rape me for? Link to comment Share on other sites More sharing options...
DirtyComanche Posted October 17, 2005 Share Posted October 17, 2005 Transmission shop will rape you a lot... I'd just take a stab at rebuilding it, and if I screwed it and blew it up I'd probably just find another and try rebuilding that one too. I wouldn't try doing it in a weekend though. And big lock ring pliers will be your friend. Link to comment Share on other sites More sharing options...
87manche Posted October 17, 2005 Author Share Posted October 17, 2005 well, I could borrow a car to get me to work and back, Perhaps take about a week and do it. The service manual says all the tools needed, so I'd have to get those. I figure that if I can take a clock apart and put it back together then I should be able to do a tranny, it's just a big geartrain Link to comment Share on other sites More sharing options...
DirtyComanche Posted October 17, 2005 Share Posted October 17, 2005 Trans would be easier than clock. At least for me. I can't deal with small things, my fingers are too big. Link to comment Share on other sites More sharing options...
Pete M Posted October 17, 2005 Share Posted October 17, 2005 I took my peugeot apart and it was a blast! Oh wait, you'll probably be using wrenches and pliers, not the sawzall and sledge. Oh well, I'm sure your teardown will be fun too. :D Jeep on! --Pete Link to comment Share on other sites More sharing options...
mjeff87 Posted October 17, 2005 Share Posted October 17, 2005 This'll help ya some.... http://www.pirate4x4.com/tech/billavist ... n_AX15.pdf Jeff Link to comment Share on other sites More sharing options...
87manche Posted October 17, 2005 Author Share Posted October 17, 2005 eah I got the service manual. I've also got a friend that's a retired Chysler master mechanic. some horsetrading might be in order. Link to comment Share on other sites More sharing options...
87manche Posted October 18, 2005 Author Share Posted October 18, 2005 well, I talked with my mechanic friend, he said it sounds like the main shaft bearing. SO that sucks. hopefully it will last another 2 weeks or so until I get it fixed. Good new is I found a place with a lift to work on it. So no crawling on the concrete with a tranny :) Link to comment Share on other sites More sharing options...
