So I find out that my Uncle has finally given up all hope of fixing
his early 90s S-10. It took a mild sideways hit to the front corner,
just enough to destroy the suspension on that side and tweak the
frame. He asked me if I could part it out for him. Apparently 2wd +
100k miles = not a whole lot. My research has shown that whole trucks
that *haven't* been hit but otherwise don't run right for some reason
or another go for $300 or less, high mileage engines don't exceed
$200. I haven't seen the truck for a couple years now so I don't
remember exactly what condition everything is in, so I gotta go check
it out and help my cousin revive the poor thing before I make any
final decisions. But if everything checks out, I think I can convince
my dad to buy it so I can put the driveline in my 86 MJ (technically
speaking it's *his* MJ since he bought it off me so I had a down
payment for the Dakota). The swap won't happen till after the Dakota
is sold and that 351M is sold and the 88 MJ is fixed again, but
someday. The 86 is a 4x4, but that particular feature hasn't been
used since I bought it 5 years ago (3 years ago I stole the shifter
from it for use in the 88). The 180k+ mile 2.8L is most definitely on
it's last legs and I was thinking of a 3.4L until this came up. The
86 is missing the dash, the wire harness was removed by the previous
owner because of a wire fire, and overall there's barely anything I
need to remove to make way for the 4.3L stuff. And I'm talking about
swapping in ALL of the stuff. Dash included if I can. That should
make my life easier since I don't have to splice two harnesses
together or two drivetrains together.
So far I've determined that I'll need to solve these issues:
-Radiator. The old one is, well, old. I'll be trying a new stock
Jeep one before I try a custom one.
-Motor mounts. Advance adapters wants $170 for theirs. =:-o I don't
think so. I'll be attempting to fab my own before I fork over that
much loot.
-tranny mount and crossmember. Shouldn't be too hard to fab something up.
-exhaust manifold. AA says to use 78 MonteCarlo parts but I've read
that an Astro manifold works too.
-rear drive shaft. As long as a 4x4/longbed rear shaft is, taking the
t-case out of the picture means I need an even loooonger one.
-Wiring. I'm hoping to use the steering column and dash from the s-10
because I think fabbing it into the truck would be easier than
splicing all those wires. Of course, the fact that I don't have any
wires to splice *in* to makes the decision easier.
Hmmm, anything else? Basically at this stage I'm looking for the
questions that I should be asking, so if you can think of them, let me
have 'em. Anyone know of a good writeup for swapping a 4.3 into the
MJ/XJ?
Jeep on!
--Pete
P.S. I love this stage of a project! Where absolutely *anything* is
possible 'cause not a cent has gone into it. :-)
there are a couple posts on this on naxja. I know for it has been done. Might wanna check that out. Swapping steering coulmns shouldnt be a big because jeep used GM coulmns.
I found the one I bet you're thinking of just a few minutes ago. Dropping that engine into a 4wd truck sounds pretty expensive. I'm betting I can do this pretty darn cheap since it'll just be 2wd and I don't really care what the end result looks like. There's a ton of time between now and when I finally have time to do it so there's a chance I may find another decent bodied MJ to do this to. All I need is a reasonably rust free MJ with like a blown engine or something for dirt cheap. Oh, and near enough that I can go fetch it. :D
Jeep on!
--Pete
  • 10 years later...
I no longer have the MJ it was going into either. :(
(nor the room to store it, the time to build it, or the cash to transport it, etc, etc) :( :( :(
That sounds like a country music song. At least your dog didn't die
