cant find a 4x4 conversion thread
So i searched for like 35 min and couldnt find a good thread for converting to 4x4. :fs1:
From what i understand i need to get an XJ with the same engine and gears as the MJ, swap in the tranny, tcase, front axle, front driveline and have a rear driveline cut down, and swap in the center console so the tcase shifter will fit and everything is a bolt on with no fabbing except for the rear driveline. Am i correct :nuts: Does anybody have a link to swapping a shortbed 2wd 4cyl to 4x4?i can't find the thread
It is literally as easy as you listed. Everything is bolt on, other than that you'll have to drill four little holes for the linkage bracket on the body to be mounted. There's dimples there, so you'll know where to drill.
But yeah... just move everything over. If you're dealing with automatics you may have a problem with the trans computer year. Not sure though.
Best way would be to have your rear driveshaft cut down. Gonna be a lot easier than finding a shaft that's the right length.
