jsc7002 Posted February 3, 2009 Share Posted February 3, 2009 I was wondering how hard would it be to convert the MJ from the 2.5L with the Torqueflight 904 to a 4.0L with the AX15? will everything bolt up or or will just cost too much to make it worth while? thanks Link to comment Share on other sites More sharing options...
Pete M Posted February 3, 2009 Share Posted February 3, 2009 It's a lot of work for an 86. Everything needs to be swapped, including all the wire harness and the front radiator supports (to fit the 4.0 radiator, the hood needs to be swapped for the later models with the corner latches, which means everything surrounding the new latches will need to be changed). A complete donor vehicle is highly recommended. An easier swap would be to change your auto to an AX-5 manual. Link to comment Share on other sites More sharing options...
jsc7002 Posted February 3, 2009 Author Share Posted February 3, 2009 well poop lol. okay how good of an engine is the 2.5? and I thought the AX-5 was kind of crappy?? Link to comment Share on other sites More sharing options...
jsc7002 Posted February 3, 2009 Author Share Posted February 3, 2009 oh and also what all will I need to get the manual trans? obviously the manual trans itself and the pedals, clutch, flywheel, etc. is there a list somewhere of what Ill need? one more question, how good is the torqueflight 904? Link to comment Share on other sites More sharing options...
Pete M Posted February 3, 2009 Share Posted February 3, 2009 Far as I can tell, the torquefite has a good rep. A bit of an old design though, and it doesn't have overdrive. The big problem is that the 2.5L doesn't do well when mated to any auto. There's just not a lot of power and the auto sucks more of it away. There are kits out there for mating an AX-15 to the 2.5L if you're concerned about strength. What size tires are you running? Do you know the gear ratio? Link to comment Share on other sites More sharing options...
jsc7002 Posted February 3, 2009 Author Share Posted February 3, 2009 I don't know the gear ratio or the tire size, the tires are probably about 29", the whole thing is stock, but I will be lifting it to fit ~33", so the 2.5L with a manual is pretty good? Link to comment Share on other sites More sharing options...
1974CJ5 Posted February 3, 2009 Share Posted February 3, 2009 jsc7002 said: so the 2.5L with a manual is pretty good? If you mean pretty good as far as reliable, then yes it is pretty good, probably a little better than pretty good. If you mean pretty good as far as powerful, then no. I have a 2wd with 2.5 and ax4 manual with 3.55 gears. Even with the absence of the weight of the dana30 up front and a transfer case, I wouldn't say the power is pretty good. I would say adequate. .410 gears would help. With a pre 87 you are a little stuck with the drivetrain swap. You can mate an ax15 to a 2.5 with some Dakota parts here. http://www.pirate4x4.com/forum/showthread.php?t=181361, this seems pretty involved so I would make really sure this is what you want to do. There are some online parts lists that can be found with some searching. Also, you could look into a non jeep drivetrain. Like a chevy 4.3, some guys on the forums have managed to pull this off very successfully, but I don't know the details. Link to comment Share on other sites More sharing options...
Pete M Posted February 3, 2009 Share Posted February 3, 2009 jsc7002 said: I don't know the gear ratio or the tire size, the tires are probably about 29", the whole thing is stock, but I will be lifting it to fit ~33", so the 2.5L with a manual is pretty good? What axles and gear ratio are you planning to use? Link to comment Share on other sites More sharing options...
jsc7002 Posted February 3, 2009 Author Share Posted February 3, 2009 I was hoping to keep the stock axles, the front is the D30 and the rear is a D44, for gears I'm not sure 4.56 or so Link to comment Share on other sites More sharing options...
jsc7002 Posted February 3, 2009 Author Share Posted February 3, 2009 Pete M said: It's a lot of work for an 86. Everything needs to be swapped, including all the wire harness and the front radiator supports (to fit the 4.0 radiator, the hood needs to be swapped for the later models with the corner latches, which means everything surrounding the new latches will need to be changed). A complete donor vehicle is highly recommended. An easier swap would be to change your auto to an AX-5 manual. what else is needed? This is just pretty much going to be my weekend warrior and fun toy, so I have plenty of time to wrench on it and I have access to plenty of XJs. So I need: 4.0L motor wire harness radiator supports MJ hood--does the XJ hood also fit it? AX-15 trans thats not too bad sounding lol Link to comment Share on other sites More sharing options...
Pete M Posted February 4, 2009 Share Posted February 4, 2009 You'll need an entire 4.0 XJ. A complete donor rig comes highly recommended by those who have elected to take on a similar swap. Your t-case won't bolt to an AX-15, so add that to the list. Find out what ratio you have in the axles and let us know. :thumbsup: Did you swap the Dana 44 in? Link to comment Share on other sites More sharing options...
jsc7002 Posted February 4, 2009 Author Share Posted February 4, 2009 no, I havent bought it yet and it is completely stock, I don't know if I will be buying it now, the guy is only asking $200 for it and its all there but he is taking the engine, and I am having a hard time finding a 2.5, so I think I might pass and just put that money into my KJ. Link to comment Share on other sites More sharing options...
Falder Posted February 4, 2009 Share Posted February 4, 2009 jsc7002 said: I was hoping to keep the stock axles, the front is the D30 and the rear is a D44, for gears I'm not sure 4.56 or so You sure the rear is a D44 and its stock? Or maybe its a D35. Link to comment Share on other sites More sharing options...
