Will an intake from a 2000 TJ 4.0 work on my 89 4.0? If the throttle body on the intake is from a manual tranny would I need to swap the throttle body from my automatic onto it? Will it fit?
No the TJ uses a HO throttle body and the 89 is a renix throttle body...the intakes on a HO slip over and uses a clamp to hold them down...the renix uses 3 hex head bolts to hold the intake tubes down..you can make it work but its difficult
After going back and reading the write up on gojeeps site again I see that the upgrade was from an earlier HO to a later HO.
Does anyone know of anyone getting this to work on an Renix era 4.0?
it WILL NOT work with a renix throttle body which is what you have...the TJ intake will only work with a H.O. throttle body...so unless you swap the thottle body it won't work...it doesnt matter if its an Auto or Manual
Yes, I know that. The intake I was thinking of buying has an HO intake with it. Thats what my second question was referring too. I was asking about auto or manual TB. Doesnt the auto TB have extra brackets for the throttle cable and stuff that the manual does not have.
The auto has a TV , kickdown cable for the tranny. And the renix tps has another set of outputs for the tranny..
