manche Posted January 21, 2009 Share Posted January 21, 2009 will a 85 cherokee 2.5l transfer case mount up to a 89 comanche 2.5l engine?? Link to comment Share on other sites More sharing options...
bigd44889 Posted January 21, 2009 Share Posted January 21, 2009 2.5 to a 2.5 should Link to comment Share on other sites More sharing options...
aemsee Posted January 21, 2009 Share Posted January 21, 2009 You will find that you need a transmission between the two :D . IIRC, the 85 XJ did not use the 231 T-case that you have in your 89. It will probably bolt up fine, but it is different. 207??229?? Someone with some brain cells help me out here. :( Link to comment Share on other sites More sharing options...
pingpong Posted January 21, 2009 Share Posted January 21, 2009 It should be a 207 at least thats what is in my 85 xj, but they are the same. Link to comment Share on other sites More sharing options...
