jeepaholic Posted January 18, 2009 Share Posted January 18, 2009 what size and thread bolts are used to bolt the ax15 to a bellhousing..i can't seem to find the right ones that fit..and pete if you read this i still need that bellhousing and 8coozies..Lemme know what donation :brows: i need to send. Link to comment Share on other sites More sharing options...
Pete M Posted January 18, 2009 Share Posted January 18, 2009 Then you need to respond to my last PM. :shake: Link to comment Share on other sites More sharing options...
Pete M Posted January 18, 2009 Share Posted January 18, 2009 Did you try Metric sizes? Link to comment Share on other sites More sharing options...
jeepaholic Posted January 18, 2009 Author Share Posted January 18, 2009 I tried everything i had in the garage :dunno: ..man bad wknd for jeep work..can't find those bolts..one of the clutch bolts wouldnt come out ended up rounding it off..had to grind it off..now have to pull the prsr plate to drill and tap it..I quit after that..decided to call it a wknd. :fs1: Link to comment Share on other sites More sharing options...
Pete M Posted January 19, 2009 Share Posted January 19, 2009 It's probably not anything most people have in their garage. I believe it's a fine thread metric. But I too don't have any lying around to check. :( Link to comment Share on other sites More sharing options...
bn6339 Posted January 19, 2009 Share Posted January 19, 2009 According to some PDF factory parts breakdowns, the bolt size is dependent on the year- 1991-93 shows a M10x1.50x34 (pn 6502 442) 1994-96 shows a M10x1.25x34 (pn 6503 299) Not completely sure why there's a difference, as when I looked at my spare 1991 trans it was the second size....I would be most judicious when dealing with aluminum....if you can find either a thread gauge or a tap (which is what I used)or a sample bolt would be best....stripping the housing would be a rather expensive ouch! I tried to confirm these via Chrysler parts direct, but their website is down.....hope this helps, BSG Link to comment Share on other sites More sharing options...
