GEARS
Should be 4.10s, but I'd double check the tag if I were you. Also (if I were still standing in your shoes), I'd focus on finding a Dana 30 front that already has 4.10s in it so you won't have to regear anything. :thumbsup:
2.5L 4wd conversion shortlist:
-4wd AX-5
-21 spline t-case
-shifter linkage, handle, and make sure you get that little bracket that bolts to the underside of the floor
-front driveshaft from a 2.5L MJ/XJ
-rear driveshaft from a 4wd 2.5L MJ (or have your 2wd one cut down to size like many of us do)
-Dana 30 that matches your rear axle ratio
