So i blew a head gasket and valve cover gasket and then drove her another 8 miles, she still runs but its stuck in LIMP mode and i was wondering how hard is that head gasket?
88' Comanche L.B. 4.0 4x4
Jeep On
I didn't know the Renix control system had a "limp mode" as such. It's likely barely be able to limp because of the blown head gasket/no compression on one or more cylinders.
It's relatively straight forward as long as you have the proper tools. It's a looong procedure though. A good weekend for me. Spray down the bolts with PB Blaster for days ahead of time.
Be prepared that the head weighs a lot. Or at least it seems to when it's in the middle of the engine bay. :shake:
thanks guys but I'm givin her up and just grabbing the stuff out of it and leavin it, ill start fresh agian ive done it a few times but if anyone wants to make an offer. Its on EXIT 34 ON 1-69 in indiana about a half an hour from FT.Wayne. Call me if ya got any questions. 517-917-8408, name's jake
You're just leaving it on the side of the road? :hmm:
And you should post that in the classifieds. :teehee:
