Shane Posted January 16, 2009 Share Posted January 16, 2009 I have an 89 MJ 4x4 automatic on the column, therefore, it has PRND32-1 in the cluster. I am switching from the idiot lights over to the actual gauges w/ the tach. Is there any advice on how to modify the cluster to accomdate. I do not like the idea of having the PRND32-1 sitting on the column and I do not have the $$$ to switch to a floor shift. I will appreciate any and all advice . Thanks again. Shane Link to comment Share on other sites More sharing options...
BookspanS Posted January 16, 2009 Share Posted January 16, 2009 get the linkages, and a jeep shop right down to road from me will do it for $55 in labor. parts shouldnt go above $100. Shop in in Pickens, SC by the way, about 2 hours away from you Link to comment Share on other sites More sharing options...
HOrnbrod Posted January 16, 2009 Share Posted January 16, 2009 Shane said: I have an 89 MJ 4x4 automatic on the column, therefore, it has PRND32-1 in the cluster. I am switching from the idiot lights over to the actual gauges w/ the tach. Is there any advice on how to modify the cluster to accomdate. I do not like the idea of having the PRND32-1 sitting on the column and I do not have the $$$ to switch to a floor shift. I will appreciate any and all advice . Thanks again. Shane Didn't you ask this same question like last week? If you do not like the idea of the shift indicator sitting on the column, suggest you invest in a Dremel tool and carefully hack a slot to mount your existing indicator, then figure out a way to mount it in the new cluster as there are no mounting posts provided in the full gauge clusters. Good luck! Link to comment Share on other sites More sharing options...
Shane Posted January 16, 2009 Author Share Posted January 16, 2009 Thanks for the advice. I did not ask this question last week. If I had, I would not have asked this week, however I remember the thread , but could not locate it when I neede it. I may go w/ BookspanS advice. I'll stay in touch. Shane Link to comment Share on other sites More sharing options...
88 Beast Posted January 16, 2009 Share Posted January 16, 2009 Hello all. my first post. I installed gauge cluster last week. "88" with auto shift on column. Gauge cluster had mount posts for PRNDL mount . Careful measurements and Dremel works great. Now back to the JY for a clock, should have grabbed it when I got cluster :doh: Link to comment Share on other sites More sharing options...
HOrnbrod Posted January 16, 2009 Share Posted January 16, 2009 Some pics would be nice. :cheers: Link to comment Share on other sites More sharing options...
Shane Posted January 16, 2009 Author Share Posted January 16, 2009 Hey hey HORNBROD!!! Do you like apples? How do you like them apples??? Thanks again to those who like to help others without being rude... Link to comment Share on other sites More sharing options...
BLHTAZ Posted January 16, 2009 Share Posted January 16, 2009 Shane said: Hey hey HORNBROD!!! Do you like apples? How do you like them apples??? Thanks again to those who like to help others without being rude... Hey Shane...I don't see where he was rude :hmm: . He simply remembered that the same question was asked and thought it was you. He offered good advice from personal experience. The new guy obviously lucked up and found a rare cluster that had what he needed...it happens. If anyone is being rude, I would have to lay that one on you here... ;) :cheers: Link to comment Share on other sites More sharing options...
aemsee Posted January 16, 2009 Share Posted January 16, 2009 88 Beast said: Hello all. my first post. I installed gauge cluster last week. "88" with auto shift on column. Gauge cluster had mount posts for PRNDL mount . Careful measurements and Dremel works great. Now back to the JY for a clock, should have grabbed it when I got cluster :doh: Had the same experience putting a full cluster from a 88 in to my 87. Had mounting posts. IIRC, had to modify something to be able to use them though. But it worked. And Hornbrod is correct, a dremel tool is your friend. Link to comment Share on other sites More sharing options...
phenryiv1 Posted January 16, 2009 Share Posted January 16, 2009 hornbrod said: Shane said: I have an 89 MJ 4x4 automatic on the column, therefore, it has PRND32-1 in the cluster. I am switching from the idiot lights over to the actual gauges w/ the tach. Is there any advice on how to modify the cluster to accomdate. I do not like the idea of having the PRND32-1 sitting on the column and I do not have the $$$ to switch to a floor shift. I will appreciate any and all advice . Thanks again. Shane Didn't you ask this same question like last week? If you do not like the idea of the shift indicator sitting on the column, suggest you invest in a Dremel tool and carefully hack a slot to mount your existing indicator, then figure out a way to mount it in the new cluster as there are no mounting posts provided in the full gauge clusters. Good luck! That was me that asked it last week. Link to comment Share on other sites More sharing options...
HOrnbrod Posted January 16, 2009 Share Posted January 16, 2009 phenryiv1 said: That was me that asked it last week. This question: viewtopic.php?f=2&t=13955&p=140652#p140652 Still would like to see some pics. Link to comment Share on other sites More sharing options...
Shane Posted January 17, 2009 Author Share Posted January 17, 2009 My intentions in this thread was not to offend any one. I got carried away. I fmy remarks ruffled ant feathers I apologize for that was not my intention Thanks to all for the great advice. Shane Link to comment Share on other sites More sharing options...
88 Beast Posted January 17, 2009 Share Posted January 17, 2009 I must have been REAL lucky because I got two clusters in case one didn't work. Both had mount for PRNDL. One from an "88" and one from an "89" Chero. Both worked but I used the "88" because it was within 400 mi. of my "dummy" cluster. Still got the "89" just in case. Link to comment Share on other sites More sharing options...
HOrnbrod Posted January 17, 2009 Share Posted January 17, 2009 Wonderful. Got any pics? Link to comment Share on other sites More sharing options...
phenryiv1 Posted January 17, 2009 Share Posted January 17, 2009 hornbrod said: phenryiv1 said: That was me that asked it last week. This question: http://www.comancheclub.com/forums/view ... 52#p140652 Still would like to see some pics. :oops: My mistake- I forgot that we had already teamed up on him in that other thread. Shane- See the thread that I had (link was in your thread from last week) for more info on this swapover. Link to comment Share on other sites More sharing options...
