tmmoll Posted January 8, 2009 Posted January 8, 2009 Please help..... When I drive above 25-30mph, there is a noise that I don't know what it is. It sound like rubber on concreate at high speeds but it comes and goes, and when I take my foot off the gas it will stop for a minute. The tires are almost brand new. And I think they are the right size.....225's. Any help?
BLHTAZ Posted January 8, 2009 Posted January 8, 2009 What is your set up? Engine, transmission, t-case?? Check you fluids in tranny, t-case & axles. Check the ujoints out in the driveshafts too. If you have a 5 speed...does the noise stop or change when you push the clutch?
tmmoll Posted January 8, 2009 Author Posted January 8, 2009 Well it a 2.5 4 speed, all stock ride height. I havent checked the fluids....I probable should before posting. Ill check those when I get home tonight and let you guys now.
tmmoll Posted January 9, 2009 Author Posted January 9, 2009 Well last night I couldnt check any thing. It got too dark. Doesnt matter though, I went to go move the truck out of the driveway and it wouldnt start. It turned over but nothing else.
BLHTAZ Posted January 9, 2009 Posted January 9, 2009 I went to go move the truck out of the driveway and it wouldnt start. It turned over but nothing else.When that happens, it's typically the CPS that has gone bad.
