jpdocdave Posted January 3, 2009 Share Posted January 3, 2009 hey guys, long time jeeper here, yj wranglers and xj's, and i love the mj. i currently have 2 yj's and i'm on my 3rd xj. here's the question. i've been looking for one for quite a while. they are either all 2 wd or 6 grand. i might have found a candidate, 4.0 auto 4wd and its the heavy ton, or at least it has a sticker. i never knew about this option till i did some research. the truck is a few hours away, and i know the heavy ton will have a d44 rear axle, but i haven't been able to see it yet, so is there any other tip offs as to if this is actually a heavy ton, or just a sticker, what else can i look for? what else can you tell me about the heavy ton, all i can get is wikipedia crap. what can it really tow? :hmm: thanks guys. Link to comment Share on other sites More sharing options...
johnnyc Posted January 4, 2009 Share Posted January 4, 2009 The sticker actually says "Heavy Ton"? Do a search here for "Metric Tonne". Looks like the Metric Tonne will be a longbed (7 ft) and have leaf springs with 5 leaves. Link to comment Share on other sites More sharing options...
jpdocdave Posted January 4, 2009 Author Share Posted January 4, 2009 thanks, i was starting to think i didn't take a shower or something, not even a hi. :D i did a search, and didn't come up with much. ya the sticker says heavy ton 2,205 lbs. its in the rear window, all proud ya know. its a pioneer, long bed, so thats all right. just wonder if there's anyother give aways to make sure. Link to comment Share on other sites More sharing options...
Pete M Posted January 4, 2009 Share Posted January 4, 2009 The Dana 44 is a good indicator. :D As are the leaf packs. They have a 4+1 instead of the regular 3+1 leaf setup. 2wd isn't much of a problem since it's a bolt-in procedure to convert to 4wd using stock MJ/XJ parts. :thumbsup: Also, the package goes by a few different names, including Big Ton, Heavy Ton and Metric Tonne. Link to comment Share on other sites More sharing options...
jpdocdave Posted January 4, 2009 Author Share Posted January 4, 2009 great, thanks for the help. actually it does say big ton. i'll know if its a d44 when i see it, and now i know to look for the springs. i just wanted to make sure its not just a sticker. or even someone just swapped in a d44 and put a sticker on it. so what do you guys think of the big ton? is it a worthwhile platform? it sounds like it to me. just want some pros opinions. thanks again for the help. Link to comment Share on other sites More sharing options...
