Cold Air Intake?
If it is on a cherokee or comanche it is a waste of time. You can build a heat shield to separate the filter from the hot exhaust manifold to make it a little better, but not really worth the time. I took the home made setup I had on my stroker OFF, with no noticeable change in power. Even with a Pro built kit, the most you are looking at is about 3HP.
I would leave the stock airbox on, put a flat panel K&N in, and leave it at that. The box will also go a long ways in stopping a potential hydrolocking. If your box has the venturi piece in it, you can remove that for a bit of a gain as well.
