JeepcoMJ Posted December 28, 2008 Share Posted December 28, 2008 black is negative. screw holes are put there at the factory regardless of whether or not they get the speakers installed. Link to comment Share on other sites More sharing options...
phenryiv1 Posted December 30, 2008 Share Posted December 30, 2008 Try entering a hard return between pictures to avoiud the need to side-scroll. I pulled the drivers side b pillar trim off and found old screw holes for the speakers and a connector. Is this the speaker connector/wires, if so, which is positive?Negative? There is a green with yellow tracer and a black with yellow tracer: I had typed 3-4 paragraphs and the server crapped out on me...I will summarize: Black is negative, green is positive, and that is the stock speaker harness, but... I would run new wires to the rear and the doors, then use your own connectors to make installing the aftermarket speakers easier. If you find OEM spacers/adapters, your aftermarket speakers may not slide right in. If you have to make your own, try using the stocker as a template and use plexiglass to make your own adapter. Link to comment Share on other sites More sharing options...
project88mj Posted December 30, 2008 Share Posted December 30, 2008 6x9 belong in the door and as for be hind the seat......... Link to comment Share on other sites More sharing options...
Akula69 Posted December 30, 2008 Share Posted December 30, 2008 Yes those are the speakers connectors. I used a set of 4x6 out of a late model TJ for mine, but the connectors sis not fit and had to be replaced. Link to comment Share on other sites More sharing options...
