djag12 Posted December 17, 2008 Share Posted December 17, 2008 Will a wrangler rear axle fit the mj? Link to comment Share on other sites More sharing options...
Pete M Posted December 17, 2008 Share Posted December 17, 2008 Yes, but you'll have to weld perches on the the proper spot. Link to comment Share on other sites More sharing options...
djag12 Posted December 17, 2008 Author Share Posted December 17, 2008 OK. I just didn't know if they where the same width. I have the chance to get a 8.8 installed for $400. Person had it in his Wrangler but it came from a 2003 Explorer. Has disc brakes and a limited slip locker, guess I need to check the bolt pattern also. Thanks Pete Link to comment Share on other sites More sharing options...
HKB3 Posted December 17, 2008 Share Posted December 17, 2008 Bolt pattern is the same, 5 on 4.5" Link to comment Share on other sites More sharing options...
djag12 Posted December 17, 2008 Author Share Posted December 17, 2008 great. :cheers: Link to comment Share on other sites More sharing options...
BREEZE1 Posted December 17, 2008 Share Posted December 17, 2008 go with the 8.8!!! i love mine!!!! :cheers: Link to comment Share on other sites More sharing options...
BLHTAZ Posted December 17, 2008 Share Posted December 17, 2008 Diane...you didn't mention the gear ratio...is it the same as yours? Link to comment Share on other sites More sharing options...
reson46 Posted December 17, 2008 Share Posted December 17, 2008 Has disc brakes and a limited slip locker Limited slip and locker are not the same type of differential unless it is a selectable locker that is a limited slip when off. Willy Link to comment Share on other sites More sharing options...
