tallon2064 Posted November 23, 2008 Share Posted November 23, 2008 Does anyone know of a good way to seal around the fuse box(firewall penetration)? Is there a gasket or would permatex be better. Last time it rained hard out found water coming in around it. Wasn't driving so i figure it's coming in through worn hood seal or getting in from cowl drain being stopped up, am going to try to fix both but I know water shouldn't come through the firewall regardless. The reason i checked is the nasty wet carpet syndrome. Link to comment Share on other sites More sharing options...
87mjdriver Posted November 23, 2008 Share Posted November 23, 2008 I just used some silicone sealant on the engine bay side, and sealed around the fuse box opening. Link to comment Share on other sites More sharing options...
Pete M Posted November 23, 2008 Share Posted November 23, 2008 When I had a similar thing happen in my 88, the water was leaking from the hood seal (the one at the back of the hood), dripping into the engine bay and following an wire down through one of the firewall holes. Link to comment Share on other sites More sharing options...
