Has anyone here upgraded their headlight wiring? I followed this write-up: http://gojeep.willyshotrod.com/HowtoHeadlightLoom.htm and I’m officially stuck.
Here are my problems when all the wires are connected (as instructed in the write-up):
1. With light switch off, one low beam headlight is on. :???:
2. With headlight switch on, both low beams come on. :yes:
3. With high beam switch engaged (pull the turn signal stalk), no lights at all. :dunno:
I've mixed and matched the high & low beam wires between the relay pins and I can get the highbeams to go on individually or at the same time, but I can't wire it up so everything works as it should.
Can anyone offer a clue as to what might be wrong here? Not sure if it matters, but I'm using 30 amp relays & I don’t have fog lights.
Wow sounds kinda cool. So you can actually make it "wink"?
You might pick up some chicks with that one.
Sorry man I couldn't help it.
I have no clue. Put it all back the way it was. I did a complete upgrade with wiring and new lights. Best thing I ever did for mine.
Hornbrod did it on his 92 too and he sent me all the info in a PM. I'm not saying it was cheap either cause it ran me 100.00 plus but the end results are excellent. I HIGHLY recommend the change so you might PM him and ask him directly.
James and Sugarfoot
1988 4.0 4x4
Austin TX
GO HORNS!!! YEE HA!
South Austin: We're all here cause we're not all there.
This is the diagram I sketched down, sorry about my paint skills I'm a little special :clapping: , hopefully you can read all of it
Hope this helps.
Jonathan
