Oizarod115 Posted November 15, 2008 Share Posted November 15, 2008 i got a fluid sentinel from an 85 i'll put up pics later! 5 bucks! i need to go back and get all the sensors. Link to comment Share on other sites More sharing options...
mfpdm Posted November 16, 2008 Share Posted November 16, 2008 You lucky dog. :nanner: I always hope to find one each time I hit the JY but no such luck.........Yet. :yes: :cheers: Link to comment Share on other sites More sharing options...
jbhill Posted November 16, 2008 Share Posted November 16, 2008 is that the secret service for the fluid? :needpics: Link to comment Share on other sites More sharing options...
aemsee Posted November 16, 2008 Share Posted November 16, 2008 Maybe that is what the mystery flopping connector is for that bilgamesh has? Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 16, 2008 Share Posted November 16, 2008 Link to comment Share on other sites More sharing options...
BookspanS Posted November 16, 2008 Share Posted November 16, 2008 Where did you get the woodgrain hornbrod? Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 16, 2008 Share Posted November 16, 2008 Not my rig, just a pic of the Sentinel panel. I had one for awhile, but decided it was not worth finding all the sensors to wire it up. But this woodgrain pattern can be found on the late 80's XJ Wagoneers. Link to comment Share on other sites More sharing options...
BookspanS Posted November 16, 2008 Share Posted November 16, 2008 Ok. That looks like it would be very helpful to have Link to comment Share on other sites More sharing options...
Boilermaker Posted November 16, 2008 Share Posted November 16, 2008 If you haven't already, make sure you get the remote module (should be light blue and mounted at the bottom of the dash, near the driver's right knee). This may also help: Sentry System Wiring (.pdf file) If you need pictures of anything to help you find what you're looking for, i have most of the system in a box around here somewhere. If you are going to do the basic fluid sensors that work off just the display module, let me know, i could put the remote module to good use. Link to comment Share on other sites More sharing options...
Oizarod115 Posted November 16, 2008 Author Share Posted November 16, 2008 i'm either gonna sell it or go back and pull the rest of it, i found it at closing time and had only taken a screw driver cause we hit up the lot on the other side of town before and got what we needed. pulled the remote module but didn't bring it home thinkin bout lookin up the wiring and seeing if i can make it work without the remote box Link to comment Share on other sites More sharing options...
Boilermaker Posted November 16, 2008 Share Posted November 16, 2008 thinkin bout lookin up the wiring and seeing if i can make it work without the remote box It should work, but just coolant level, washer, power steering and brake fluid indicators (if you grab those sensors). You may also need to do some splicing to make the clock work; the wiring probably changed between 86/86 and your 89. If you look underneath the truck, the part of the wiring harness that runs to the axle and transfer case sensors will be pretty obvious. btw, all three of those sensors are the same; the axle sensors are easy to get to, the tcase not so much. I was never able to figure out where or what the brake pad sensors were. A few chrysler vehicles had brake pad sensors; late '80s lebarons came with a something called a traveler that was basically an electronic version of the XJ sentry system. Depending on what you grab and want to use for yourself, i might be interested in some of what you don't want. I have an extra display box and some sensors; with the remote control box, wiring and a few more sensors a second working system can be put together and someone else around here can use it. Link to comment Share on other sites More sharing options...
