Grand Cherokee front sway bars
Hey fellows,, What is the years for the upgrade sway bars in the Grands? I found me another Jeep honey hole and they have a few Grands there. The big question is would anybody know the diameter of the big bar? They have a few front axles sitting around but the only way I'll know if its the big one is take my calipers with me.
And I'll need the strap frame mounts to right? TIA, jt
  goblazers_6 said:
I measured both the stock and the V8 ZJ bar with a micrometer and I had come up with
Stock MJ - 23mm
V8 ZJ - 27mm
its all in my write up.
http://comancheclub.com/forums/viewtopi ... 80&start=0
And I believe any V8 ZJ bar is a driect swap. Its a great upgrade. Every Comanche owner should do it.
I knew it was somewhere on here!!! Thanks man. :thumbsup:
  jtdesigns said:
DUH.... :doh: I guess I could just go measure the one I have now huh?? Then make sure to find one thats bigger... Doo Dee Duh.....
Thanks C-Dub
You want me to pick you one up too if I can find one?
It would be greatly appreciated!! At least LMK, so I can make arrangements for my proqurement. :D :brows:
CW
