jtdesigns Posted November 14, 2008 Share Posted November 14, 2008 Hey fellows,, What is the years for the upgrade sway bars in the Grands? I found me another Jeep honey hole and they have a few Grands there. The big question is would anybody know the diameter of the big bar? They have a few front axles sitting around but the only way I'll know if its the big one is take my calipers with me. And I'll need the strap frame mounts to right? TIA, jt Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted November 15, 2008 Share Posted November 15, 2008 don't know the size, but I too would like one and am keeping my eye open for one on boards.. JUST GET A V8 front sway bar and it will be larger than what came on our MJ's. CW Link to comment Share on other sites More sharing options...
jtdesigns Posted November 15, 2008 Author Share Posted November 15, 2008 DUH.... :doh: I guess I could just go measure the one I have now huh?? Then make sure to find one thats bigger... Doo Dee Duh..... Thanks C-Dub You want me to pick you one up too if I can find one? Link to comment Share on other sites More sharing options...
Darren Posted November 15, 2008 Share Posted November 15, 2008 I measured both the stock and the V8 ZJ bar with a micrometer and I had come up with Stock MJ - 23mm V8 ZJ - 27mm its all in my write up. viewtopic.php?f=9&t=11980&start=0 And I believe any V8 ZJ bar is a driect swap. Its a great upgrade. Every Comanche owner should do it. Link to comment Share on other sites More sharing options...
jtdesigns Posted November 15, 2008 Author Share Posted November 15, 2008 I measured both the stock and the V8 ZJ bar with a micrometer and I had come up with Stock MJ - 23mm V8 ZJ - 27mm its all in my write up. http://comancheclub.com/forums/viewtopi ... 80&start=0 And I believe any V8 ZJ bar is a driect swap. Its a great upgrade. Every Comanche owner should do it. I knew it was somewhere on here!!! Thanks man. :thumbsup: Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted November 15, 2008 Share Posted November 15, 2008 DUH.... :doh: I guess I could just go measure the one I have now huh?? Then make sure to find one thats bigger... Doo Dee Duh..... Thanks C-Dub You want me to pick you one up too if I can find one? It would be greatly appreciated!! At least LMK, so I can make arrangements for my proqurement. :D :brows: CW Link to comment Share on other sites More sharing options...
