BookspanS Posted November 14, 2008 Share Posted November 14, 2008 Just bought a set of NOS running boards from djag12, and was wondering if ANYONE here knew where they bolted up to or if I would have to whip out my drill Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted November 14, 2008 Share Posted November 14, 2008 Sell them to a mall crawler, along with the nuts and bolts Then build a set of rock rails and WELD THEM to the frame. Now you can use them to cilmb in your rig.... :eek: :D CW Link to comment Share on other sites More sharing options...
SuperWade2 Posted November 14, 2008 Share Posted November 14, 2008 Sell them to a mall crawler and build a set of rock rails to use to cilmb in your rig.... CW :clapping: :rotfl2: :rotfl2: :rotfl2: :rotfl2: :rotfl2: :rotfl2: Link to comment Share on other sites More sharing options...
smithe1811 Posted November 14, 2008 Share Posted November 14, 2008 :wall: Link to comment Share on other sites More sharing options...
Oizarod115 Posted November 14, 2008 Share Posted November 14, 2008 sorry man, i don't think anyone here is gonna know, i've never seen a set that i know of Link to comment Share on other sites More sharing options...
BookspanS Posted November 14, 2008 Author Share Posted November 14, 2008 Well I am working on a deal to get an '88 SWB to do my wheeling in, and my '86 LWB is just going to be my DD and I just gonna try to make it look nice Link to comment Share on other sites More sharing options...
JeepcoMJ Posted November 14, 2008 Share Posted November 14, 2008 you have to whip out your drill. drill some holes in the pinch weld (measure accordingly...the bolts are already on the running boards), assemble the running boards, mark mounting holes, drill, then use self-tapping bolts to finish it off. my advice... cut out the aluminum verticals, and make your own steel ones. the aluminum on body sheetmetal causes corrosion, and also with the vertical part intact, you cannot wash your floorboards or up behind the bedsides. it WILL rust, and it will be very bad. I got a swb 89 MJ with absolutely immactulate floors and inside of the bed, at 250k on the ticker, and the rockers and bedsides were GONE. my best advice, sell the running boards on ebay. if you really want the steps, get tube sidesteps for it (they are still available but hard to find), because they won't interfere with maintenance and they won't cause near as much corrosion. Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 14, 2008 Share Posted November 14, 2008 Sell them to a mall crawler, along with the nuts and bolts Then build a set of rock rails and WELD THEM to the frame. Now you can use them to cilmb in your rig.... :eek: :D CW Those things are butt fugly, on a mall crawler, on a low rider, on a trail rig, on any MJ. Got to agree w. the CW-man again - damn! :D The Al vs. steel bonding will create a corrosion problem as JeepCo mentioned; it's just not worth the aggravation. Sell them out on Ebay mate. Just MHO. :cheers: Link to comment Share on other sites More sharing options...
