I am getting a clutch kit put in my manche this week. Is there anything else I should have done while everything is ripped apart? It is the Peugeot tranny. So far this is what I am having done:
LuK Clutch Kit (Pressure Plate, Clutch Disk, Release Bearing with internal Slave, Pilot Bearing)
hydraulic line
I'm no technical expert but my '86 with peugot gearbox went in for a clutch kit and bearings recently. The garage also had the pressure plate(?) skimmed.
86 came with the AX4 4 speed, the AX5 5 speed, or substituted by a T5 or T4. the peugot never even had a bellhousing that would mount it to a 60 degree gm bellhousing, which is what the 2.5 4 cylinder and the 2.8 v6 both have.
