header question
I really think that an ho header will bolt right up to my renix I think that the only difference is the angle of the down pipe. I have a ho header, and a cracked renix manifold. I also have the ho down pipe. How can i test this with out taking my jeep all apart? If I took it into my local auto parts store and test fit a gasket from a renix and all the holes lined up, would that mean that it will work? I know that it will bolt on.
jamminz.gif The ports do line up! I went to the local auto parts store and sized it up with a renix manifold gasket. it was an exact match. The only only hurdles that I have to over come now is that the o2 sensor goes on the down pipe, wich is cool because i grabbed the HO down pipe, and I have to figure out how to re-work the EGR system because there is no hose going to the manifold now. any ideas?
