incorrect locker install??
So, I left my posi lok engaged this morning on the way to work. I went to make the turn into the parking lot and the thing wouldn't turn. I disengaged the posi lok and the thing turned like a charm. Could my front Aussie be installed incorrectly?
Low speed in 4wd or dry pavement? It should bind/hop in part time... Unless you're throttle happy and get all the tires spinning, then it's smoootherest.
With the posi-lok thingo on he's still only in 2wd, as I understand it. With a lurch-box locker I don't think you should see bind then, as it should allow one wheel to over-speed the other... Should just go clicky-clicky... So uh, somebody might have not bothered to measure the gap when they did the install... Or maybe it's working peachy and it's just my limited experience with these lockers.
