maddzz1 Posted October 12, 2008 Share Posted October 12, 2008 How do you change the bulb? The clear lens turns a little to the side but thats it. Is there a way to get the lens out w/out breaking the little clips? Link to comment Share on other sites More sharing options...
Akula69 Posted October 13, 2008 Share Posted October 13, 2008 I had to change one in my daughter's XJ...used a small screwdriver to gently push one of the contacts back till the bulb popped free. Link to comment Share on other sites More sharing options...
maddzz1 Posted October 13, 2008 Author Share Posted October 13, 2008 So you have to remove the bulb thru the side, right? The lens does not come off (w/out breaking)? Link to comment Share on other sites More sharing options...
chicofuentes0224 Posted October 13, 2008 Share Posted October 13, 2008 Yep, That's how I changed mine. Link to comment Share on other sites More sharing options...
xj_dummy Posted October 13, 2008 Share Posted October 13, 2008 Are you trying to remove the bulb from inside the truck? Go to the end of the lite and remove the whole lite, lens and frame. Then you can safely remove the bulb on the side of the lite itself. Ill post a pic of it. (Sorry for the crappy photos) View of whole lite removed. Image Not Found Carefully remove the bulb from the side to change it if your lite has worked before. Mine hasn't worked from the day I got it, so I cleaned the contacts with a small needle file. First I used a screwdriver on the end of the lens where the plug connect to the lite, next to the pivot point, carefully pry the lens off. Image Not Found Doing this will allow you to get into the lite so you can clean up all the metal contacts, on the base and on the lens. Image Not Found Link to comment Share on other sites More sharing options...
