Okay, I've been told YJ front brake hoses are 3" longer than MJ/XJ ones.
My research tells me 87 through 95 Wranglers were YJs.
Now here's the problem: there are different parts listed for 87-89 and 90-95.
So which ones do I get? Or do I go by the year of my truck because it's due to the same hub changeover that happened on the Comanches and Cherokees?
I do not think its ganna make a difference. I think its anti loc avalibility and if so has no bearing on our applications.
I am running 4" ext YJ lines on mine. don't remember for sure the year, but I THINK it was 95...
CW
I believe I used '95 YJ hoses in the '88 MJ when I had the lift in it, too. Had to re-bend the hard line on the caliper end slightly, but the fittings went together and they were plenty long enough for a 4" lift.
i went with 1990 gmc 2500 fromt hoses on my xj, they were pretty long
^Me too,screwed right in,lots of slack with 4.5" lift.
no, they have that odd metal tab like the durango ones, I just nipped it off. Heck, I got the extra length I needed for a while by unhooking that oiece and straightening out the hard line
