To all people running a 3" lift on their Comanche:
What shocks are you running in the rear?
And to all people running a 4.5" lift:
What shocks are you running up front?
If possible, I'm not only looking for the brand, but also model number. Or what stock application the shock is supposed to be for. I'm trying to find out what will work, like a stock 95 Dakota rear brake hose being 7.75" longer than a Cherokee one (and Comanche?) with the same (correct) ends.
For the OME Shocks:
Front w. 1"-3" lift: OME N35 (firm) or N35C (Comfort) (15.25"-23.75")
Rear w. 1"-3" lift: OME N40L (15.6"-25.8") (Actually a ZJ shock)
For higher lifts (3"-5"), the OME N35L will work up front but they don't make one long enough at this time for the MJ rear.
