jtdesigns Posted September 3, 2008 Posted September 3, 2008 Just installed a new one from Advanced........... and lets just say it was about a foot longer then the oem... :roll: My trucks a 2wd would it be a better fit if the truck was 4wd?
BLHTAZ Posted September 4, 2008 Posted September 4, 2008 It may be considering that it would have the added length of the t-case to span.
jtdesigns Posted September 4, 2008 Author Posted September 4, 2008 Would a foot be about the length of said transfer case?
jtdesigns Posted September 4, 2008 Author Posted September 4, 2008 Probably about 10" +/- ... not that it was a big,big problem I just had to push the cable past the spot where it goes in the trans. I just hope it doesn't bind from the extra large 90* bend....
Chico Posted September 4, 2008 Posted September 4, 2008 Hey Jt, quick question. Was the one you bought from Advance the correct width, because the one I got from Autozone was too skinny and too long? And actually, Taz do you guys sell one still with the housing because mine is now jacked?
jtdesigns Posted September 4, 2008 Author Posted September 4, 2008 Hey Jt, quick question. Was the one you bought from Advance the correct width, because the one I got from Autozone was too skinny and too long?And actually, Taz do you guys sell one still with the housing because mine is now jacked? Not sure I understand what your asking about width. Like the outside diameter of the black plastic sleeving or the inside spring ends?? My new cable seemed like it had a slightly larger OD. The ends, not sure, my old cable didnt have any. I don't know if I was suppose to do this, but I used some synthetic grease to coat the "springy" inside cable then put it in the plastic "tube" all lubed. I hope I don't run into problems later because of that, but the cable wasnt very much $$, so if it self destructs Ill just go through Brent for a REAL replacement....
BLHTAZ Posted September 4, 2008 Posted September 4, 2008 I can still get it. The 2wd cable w/o speed control is $31 CC price (+ ship). The 4wd version runs about $2 more.
Chico Posted September 5, 2008 Posted September 5, 2008 I can still get it. The 2wd cable w/o speed control is $31 CC price (+ ship). The 4wd version runs about $2 more. B, is that cable and housing or just cable?
BLHTAZ Posted September 5, 2008 Posted September 5, 2008 It should be complete as I have never seen our cables come as just the inner part. Let me take a look and see if I can find a dealer with one and get them to look at it.
