drewboy23 Posted September 3, 2008 Posted September 3, 2008 Does anyone know where I can get a mild to heavy duty rear bumper with clevis mounts for my 88' comanche. :headpop:
Pete M Posted September 3, 2008 Posted September 3, 2008 Build one. Seriously. :D Mine was simple 3x5 rect tube steel (3/16" wall) and I designed and fabbed it with nothing more than an electric die grinder and a drill. Then I took it to a pro to have it welded up proper.
Pete M Posted September 3, 2008 Posted September 3, 2008 Wait, I lied. My brackets were bent at a shop. But your design can be different. Then I built a clevis mount to go in the hitch.
drewboy23 Posted September 3, 2008 Author Posted September 3, 2008 Thanks for the pics. That is an idea I thought of though. I only have a 110 volt wire feed though. I'd have to also get it professionally welded. I'm thinking of buying the dual tube rear bumper for the wranglers and fabbing up my own adapters to mount it. Can you think of a reason why it wouldn't work?
drewboy23 Posted September 3, 2008 Author Posted September 3, 2008 I'm also having trouble loading a jeep pic on my profile any advice?
Pete M Posted September 3, 2008 Posted September 3, 2008 You mean for your avatar? email me the fullsize pic and I'll take care of the rest. petermontie@hotmail.com As to the wrangler bumper, I imagine it might work. Depends on the width. I think wranglers are a bit more narrow. A better idea is buying your own steel and making one from scratch. It'll be stronger for sure (and probably cheaper). :D
FxRacing282 Posted September 3, 2008 Posted September 3, 2008 Thanks for the pics. That is an idea I thought of though. I only have a 110 volt wire feed though. I'd have to also get it professionally welded. I'm thinking of buying the dual tube rear bumper for the wranglers and fabbing up my own adapters to mount it. Can you think of a reason why it wouldn't work? crank the heat and go slow you should be able to penetrate deep enough to take a few good hits to a tree.. or rock... or drunk driver
