Anybody run their disc brakes without backing plates? The backing plates on my 8.8 are pretty ganked up and I'd rather remove them than replace them. Any potential problems with that?
I've looked at what's required to rip them off (mainly, pulling the axle shafts), and I'm just going to cut them free of my new 8.8.
sorry, I missed 8.8. The backing plates on the 8.8 also have the e-brake shoes, so I don't know about doing away with them.
Once you pull the rotors off, you'll be able to see the ebrake shoes. Probably wouldn't hurt to cut them partially off, but I wouldn't completely remove them.
who needs e-brakes when you have an stick :banana:
Fixed it for you. :D I've proven I don't need a clutch or even fluid in the tranny to drive.
:nuts:
My plans are to installl a roll lock on the front brakes. Easier and cheaper then installing e-brake parts. :brows: POlus it will make it easy to do burnouts :banana:
